Good Morning, so I am currently putting a full Whelen Core 399 of my 2020 Ford Explorer. I have an FST, RST, Tracers (All WeCan X) then 2 Duo Ions in the Front and 2 Duo Ions in the rear. Also 2 Duo Vortex for the Rear Tail Lights and 2 Single Under the mirror V-Series.
veSo what I ha read on here is the WeCanX products hook into J18. I have 2 questions regarding this one do I have to connect the wires directly together or could I use a Terminal Block. If unable to use the Terminal Block what is the best way to connect the 4 wires to the single wire from the J18.
Then regarding the IONs correct me if I am wrong however in order to sync them through the Core I set them on steady burn for each color. Now this is the other part where I get confused. 1 I am assuming I need to wire both the Primary Color Wire and the Secondary Color Wire into the Core however do I need to put them into different Outputs or the same and do I need to do anything with the sync or other wire (Except Ground)
Next is the Vertex and the V-Series I am assuming it will be the same process as the ION if not could someone please inform me of the difference.
