Go into your PTT input under the ACM inputs at the top of the screen. Then select tones at the bottom half of the screen. Your tone should be set to “override tone PA.” If it is already set to that, then right click on your PTT input, and select “find all references.” That should tell you where and why a siren tone is activating when you use your PTT button.
