Whelen Core X Outputs Not Working
ffjwhite
Bombay, NY
Just wondering if any Whelen Gurus can help me figure out why I have all of a sudden lost output voltage on some of the wires on the low voltage side. They are random and seem to be about 3 of them. I have checked all the fuses and they are good. Is it something internally I can reset somehow or is this more or less a whelen concern I should forward to them?
NoLimitSquads
335
Minnesota
Not a guru, but Ive installed dozens of Cores. By low voltage, Im assuming that you mean low amperage, as all of the outputs should be 12v. Is all firmware current? What are the diagnostic lights? Have you disconnected all power, and re-connected? You didn’t accidentally enable low power did you?
Some Cores are bad from the factory.
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
Well I Pulled a bonehead move. I guess there was a setting under my Trans - Range setting under park that was shutting them outputs off. I forgot I did this and needed to use my Trans Park instead.
Thanks for updating us
Reactions: ffjwhite
ErikH
