For Sale Whelen Crown Vic rear Dual head Avengers (Many)
Emergency Lights
Veteran Member
I have 2 of these we just took in from a local agency that are complete. THESE ARE SOLD.
There are many that are missing the shroud, just the heads, flasher unit and base bracket but are functional.
Rear Dual Head Avengers that go around and over the third brake light.
These heads are R/B split.
Complete Units $45.00 Each Shipped -SOLD
Heads/Flasher/Bracket $25 Each Shipped.
Use them as they are or just use the heads and maybe the 2 Channel Flasher???? Make a custom project.
After getting more pictures on 23 May, I only have 2 of these that have shrouds. There may be more in a container but I have not found them yet.
Thanks
20210523_105418.jpg20210523_105422.jpg20210523_105424.jpg20210523_105426.jpg20210523_105435.jpg
Heineken
Newbie
So are these the crown vic-style avengers that go in the rear window, on top of the brake light? Or are these front-facing going under the rear view mirror?
Emergency Lights
Veteran Member
Thread Starter
rear facing around the brake light
Heineken
Newbie
This is a pic I took off of my old set in my vic... I would assume the above is the same, 'cept in R/B and not B/B. And probably different model numbers.
Emergency Lights
Veteran Member
Thread Starter
Emergency Lights
Veteran Member
Thread Starter
Sale Pending on the 2 complete units.
Emergency Lights
Veteran Member
Thread Starter
Units with shrouds sold.
Just the ones without the shrouds remain.
Emergency Lights
Veteran Member
Thread Starter
@RCFD - Dave is correct. These have 3 diodes Red and 3 diodes Blue on each board. You could send them to Mr. Wilson who changes them out for I believe 2 bucks per diode. SO and extra 12 bucks. Keep in mind I do not have any more shrouds. If you wanted, I could remove the cards, send you the assembly and remaining parts and send the cards directly to Mr. Wilson as it would be cheap to just sent them vs the entire thing. But that would be up to you to re-assemble.
Thanks
Emergency Lights
Veteran Member
Thread Starter
Thanks... I would doubt any dealers/distributors would have these either. I might convert one of my charger rear lower inner edges to these and make it alternate between all red and then all blue. maybe someone will scoop it up.
Nolines
Silver Supporter
No that's not weird at all, would be nice if we had some aftermarket people making stuff that we need
Heineken
Newbie
The complete description is:
Rear Deck TN Series
2005 Crown Victoria
Model: TLNCV5JJ
12V DC
R-B/R-B
P/N: 01-0684330-JJ B
MFG Date: 10/09
Just received mine and are in good condition and working order.
Online statistics
Members online
9
Guests online
108
Total visitors
117
Forum statistics
nherrick
Secure Browsing
Top Bottom
