Whelen Edge 9000 60” bar wiring question
Hey guys I recently acquired a Whelen Edge 60” bar from a friend. My plan is to strip it for parts for my bar on my truck, but I’m having trouble getting it to all function. Putting power to black and red make all 4 strobes fire. But anything else does nothing but make it click inside. He said it worked when he gave it to me the other day, he tested it that morning. I’ll list what color wires I have.
Black - ground
Red- power strobes
Green - ?
Blue - ?
White - ?
Brown - ?
Yellow - ?
As I said any power given to any wire other than red just makes a solenoid click inside and a strobe flicker once a while. The bar has 4 strobes, 2 flashers, and 2 take downs. The serial number and etc is scratched off the tag so no help from there.
My 9000 had a similar problem. I'm no expert so take what I say with a grain of salt. I checked the wires inside and found that I had a blown fuse. It's an in-line fuse in a yellow socket. Turns out the power supply in the center of the bar was bad. I found a replacement on eBay for $50 and it was easy to swap out. That got all my corner strobes working. My inboard strobes still weren't working so I found another blown fuse on the other side of the bar. Once I replaced that one, all strobes were firing.
alfiydi
