Whelen Edge 9m Model 9mhcdps
Chaser_771
14
Oklahoma
We just bought a "new" truck and it has that light bar on it and going to a federal signal Smart siren sm and its set up is weird! I was wondering about a wiring diagram cause bottom half of the bar is not working and also the siren is weird! When I turn on to slide 1, stuff in the slide 3 spot comes on! And yes its a horrible wire job as I am going to correct all their mistakes! Any help appreciated!WIN_20170916_13_54_37_Pro.jpg
StEaLtH2
2,159
New England
When you say the bottom half, is that the case for the front of the bar as well? Or only the rear of the bar?
Also if you read the rules you would know that you can't post just the birds nest of wires, there must be at least one pic of said bar!! (He he)
Meow someone will be along shortly to say that in fact a video is required, they may or may not be correct.
Chaser_771
14
Oklahoma
Only on the rear front all works. Sorry I did post a video but it was in wrong format hopefully its tagged on this 1!
Reactions: StEaLtH2
Jman423
Sep 10, 2010
3,391
United States
That appears to be an early Freedom lightbar, and those modules on the bottom are most l likely wired to be a traffic arrow. They may be two wire or they may be 9 wire... it depends on how the bar was ordered originally. Either way, you can use the SmartSiren to get those working too.
Chaser_771
14
Oklahoma
Thanks! I am going to call whelen on Monday and see if they can get me the diagram. I thought it was a freedom too but sticker shows a edge 9m so I was confused. I normally deal with soundoff signal so this is a new 1 on me. Also Jman hope I didn't break any rules been awhile since I posted anything.
