Can anyone venture a guess as to why this is happening?
Have a button on the HHS2200 set up as One Button Alleys for my arrowstick (first press output 3, second press output 4, third press both on, fourth press shuts off). The first press turns nothing on, the relay inside the amp doesn't even click. Second press activates the other output, and third press actives both just fine. Since both outputs are activating on press three it indicates it's neither a fusing or relay issue, which points to programming.
I tried a modified program the other day but only changed one siren tone, nothing else. I tried reprogramming the alleys button and nothing seemed to happen. I also loaded the previous, original programming and it still didn't function right. All indications are pointing to amp failure at this point.
Anyone have a suggestion to try before I call Whelen tomorrow?
