I'm a bit confused. I received two used universal mount ION TRIOs and they seem to be a bit different than my other ones. All my other units have individual control wires for each color, with the color of the wire matching the color that will be enabled. These two units have different colored wires and include a yellow wire. It appears they only have control of the colors via the flash patterns plus a white override wire. For example, you can have a single color in a pattern, dual color, or triple color. But that's it. You're locked into the colors when you set the pattern. I use a Cencom Core system to flash all my lightheads, and I need that to utilize patterns for nighttime and scene use (ie steady flash and DVI). I don't see any way to do this and utilize multiple colors. I'll have to use the ION flasher's integral patterns to use multiple colors. One wire controls on/off for the unit.
So basically, is this the case? Am I SOL if I want to use multiple colors with Core controlling the flash patterns? I had no idea this was an issue. Seems to be with 2018 and earlier mfg dates as far as I can tell. Only way to spot it seems to be that yellow wire instead of wires matching your colors in the lighthead.
Nothing's ever simple is it?
Thanks!
Dave
Thanks!
Dave
