Whelen lfl liberty. How to make each TA on its own switch?
bfpd108
3
0
Missouri
I am trying to hook up a left and right TA on a on/off/on switch and the center on a single switch. Since you have to use both ledt and right wire for center, how do I wire it across? A jumper wire?
Use two diodes to ensure that current does not flow from one trigger wire to the other trigger wire where they are both connected to the switch you use for the center pattern.
Reactions: bfpd108
Is there a reason you can't do an on/off for left, and on/off for right and then just activate both for the center function? It's still two switches.
I don't know... but I'm gonna try it out
Ahhh... gotcha. Thank you
Bonehead54
