Whelen liberty moisture issues
Da-Sarge
393
Canada
hello all I have a 49" Whelen liberty SL amber lense with take downs and allies. im getting moisture in the bar but all lenses look clear accept the clear section over the takedowns. It looks like a cold drink on a hot day with condensation. any ideas on how to go about fixing this moisture issue before it kills light heads as they are rather expensive here in Canada and the corners are really hard to find since they aren't made anymore
Do the new style end caps come in amber with allys?
Tony P
Moderator
Sep 13, 2015
1,944
Midwest, USA
Did you use the search function?
Da-Sarge
393
Canada
ive looked at those posts but was looking for other opinions as well plus the images and videos in said posts are also dead
tsquale
Oct 12, 2010
10,534
Minnesota, USA
Not sure you're going to get any different opinions than what you're getting from three lengthy threads documenting a well known issue with that bar. Not sure why you need photos of other moisture when the content of the posts is still visible otherwise...
As for the new endcaps with amber and alleys, I don't know.
Da-Sarge
393
Canada
I haven't had the liberty apart before so I'm kind of wondering how the lenses seal i did read the spacers foam can fold in causing a spot for water to get in i don't mind clear end caps if I got to in order to get this moisture issue under control
Da-Sarge
393
Canada
I stripped down my bar today the water in it was pretty bad :( thankfully cleaning all the electronics was easy i cleaned everything and found pretty much every lense spacer fome tabs were folded not in the channel on the extrusion and the clear section on the front for the takedowns the previous owner butchered the end while cutting it so now I'm looking for a 9.5" to 10" piece of clear to fix that bad piece i did put in a few of those packets like I usually do in headlights after a retrofit I'm pretty sure once I replace the butchered section of clear I shouldn't get problems anymore
Reactions: Tony P
