Whelen Piercer II Color Change
Derek W
9
USA - NY
I was wondering if it would be at all possible to change the color of a Piercer II? Either by changing the lenses or the strobe tube. Any input would be helpful.
Thank You
cmb56
746
Norrköping, Sweden
Thank You
If it is a strobe with a flash tube and the lens is changeable, it would go.
The flash tube is only emitting a white flash but more to the blue side.
That makes strobes better in blue than in red. You will have a higher light output in blue than in red.
I do not know if this light is made with LEDs, but if so, it is impossible because most manufacturers have blue LEDs with blue lens or red LEDs with red lens.
This makes a brighter color from the light than if it should have had white LEDs.
Michael
