Wanted: Modern Whelen RB6P in blue (or a blue dome)
I’m looking for a Whelen RB6P (or very similar), in blue with a high-speed rotator. Magnet mount. I might be interested in just a blue dome as I’ve been seeing some amber lights for sale and I can probably put the two together.
I have an old Responder, and I’m looking for something a little more “zippy” with a better reflector for a once-in-a-blue-moon emergency response. It’s not practical for me to install permanent, interior-mounted L.E.D.’s, and I need to comply with 360 degree visibility requirements.
The RB6 is a super bright light. They came in one speed....FAST/150 FPM. I have a NOS amber in original box. I use one, that I installed a magnrt/suction mount and switched cord and plug on. from time to time on my plow. I'm all for brightness, and found the Federal FireBeam 175 FPM to be a pretty close comparison, and easier to mount and remove with one hand verses two needed for the RB6.
I don’t mind the two-hand mount or removal… it will be thrown on in my garage en-route to an emergent call-out. I do want bright and fast flash for adequate get-out-of-my way visibility. I have a fast flash dash mount (that is probably more effective than a roof light) that will pair with the roof mount to meet the 360 requirement.
Reactions: dmathieu
I may have what you want, just don’t have the mag mount
I think I can source a magnetic mount kit. Can you send me some pictures, including the underside of the base or however the kit would mount? What are you looking to get for it?
Code2LLC
