Whelen Responder LED flasher - amps per outlet?
rwo978
196
ND, USA
Anyone know how many amps you can run on the 6 outlets of the Responder LED flasher?
I don't know the answer to your question, but the Responder LP itself has an average amp draw of 2.4 amps. If it correlates, that would be about .4 amps per module.
That's just what the bar draws.
But, what is the rating of each outlet? IE, if it were to be used in a different application, custom jobber, how many heads could be hooked up to each outlet?
I would suggest you read some more of the installation brochures, such as the 13617 Installation Guide: for the Responder® HD Lightbar Model(s): R2HD**, R9HD**, R10HD**; and then check with Whelen for technical assistance.
I have the Responder LP with Lin6 Super LED lightheads and a select six channel flasher fused at 8 amps, but an older version (R10HD) used stacked model 400 Lightheads and was fused with a fifteen amp fuse.
A warning on info sheet for the four channel ULF44 flasher reads: "This product is designed for use with 12 volt LED lightheads. Do not exceed 5 amps total current draw for each channel." Whelen Form No. 14103A (061807).
That install guide didn't say much. I just shot and email to Whelen to know for sure.
Reply from Whelen, 2 amps per outlet.
rwo978,
Glad you received an accurate reply.
Did you part out a separate flasher to use on another lightbar?
Or were you looking at customizing a Responder LP?
I built up a Responder LP with Super LED Lightheads from HPD84. I spent a lot of money to obtain red and white to the front, and red and amber to the rear, and to add magnet mounts. (It would probably been easier to custom order the thing, with as much as it has cost $$$.)
But with the six channel flasher, there are ~forty six patterns, and the rotator feature at 90, 120, 150, and 250 rpm. I can see where these flash patterns could be used in custom modifications to some other lights.
olmazey57
