Jmarico1
This Whelen S360 D was a dealer display and never installed on a vehicle. It is a Comet type flasher and has the wiring to install a switch to run on high power or low power. I has a threaded mounting hole in the bottom for pole mounting. The power cord that connects to a harness under the dome has been replaced as some point with a similar one with a similar plug to the wiring harness. The bottom of the light has some worn paint from being ted to a display. It has been tested and operates perfectly. $120 plus shipping from 14534.
