Whelen surface mounts
HFD38RESQ
31
EmerVehSolutions said:
best guess would have to be because of the size of the lighthead...
Thanks
I forgot to add one more-
par 36 why that? what does PAR stand for? There is also a par 46
May 25, 2010
7,061
Tunkhannock, PA, USA
I believe the PAR 36s are also labeled 200 series...? I've seen that label floating around too...
43 series was replaced by the 400s then replaced by the m4s
64 series was replaced by the 600s then replaced by the m6s
73 series was replaces by the 700s then replaced by the m7s
97 series was replaced by the 900s then replaced by the m9s
52 series was replaced by the 500
Pimp
1,872
Louisiana
I believe the old Whelen numbering system started with the size of the lighthead
52 series = 500 = 5x2
73 series = 700 = 7x3
44 series = 400 = 4x4
etc
SurfCityCar2
156
Jacksonville, NC
etc
I believe thats right. I remember the Whelen 43 series. The good old DashMaster 4X3 strobes. and a few of the older ones that haven't been seen in forever.
occram
62
New Jersey
You are correct in your assumption. The *00 designation assigned by Whelen corresponds to the size, in inches, of the lighthead.
Occram~
Kbellinger01
