A quick question on the Whelen TA plug connections, like the one that interfaces with the Whelen TACTL5. So my understanding is that pins 1-8 are to the power/positive wires of the dummy style lightheads in TAs, and the grounds go to y'know, chassis ground? But then there is pin 9, just labeled as "+BATTERY". Where does this 9th wire come from with only 8 positive and 8 negative wires. I'm probably just severely misunderstanding something somewhere. Below is a screenshot from the Whelen TACTL5 PDF and a hastily done diagram from my understanding that is likely wrong.
