Whelen UB412 power supply info
rwo978
ND, USA
Anyone have the wiring guide for one, I've searched all over and can't find it. Also, is it regulated or un-regulated? It's mostly sealed, so is it 'waterproof'?
Thanks!
bigcat
641
Hartford County, CT
Here is the wiring diagram for it. I'm not sure if it is regulated or unregulated. I'd say it certainly is water-resistant as moisture has been known to get into Edge bars, but I probably wouldn't mount it anywhere that it's going to be constantly exposed to the elements.
rwo978
ND, USA
Thanks!!
Any idea on the other harness? I got nothing but the 2 wiring bundles coming off it with the 2 plugs. On the second harness, there's 12 wires:
  • brown
  • black #1
  • green
  • white
  • black/white #1
  • white/purple
  • red
  • black #2
  • blue
  • yellow
  • black/white #2
  • grey
bigcat
641
Hartford County, CT
Whelen strobes usually go:
Position 1 - Red - Anode
Position 2 - Black - Cathode
Position 3 - White - Trigger
I can look at the "official" wire setup a little later today for you but as long as you have one of each, the strobe should fire.
I think it usually goes
1 Brown
2 Black
3 Green
1 Red
2 Black
3 Blue
1 White
2 Black/White
3 White/Violet
1 Yellow
2 Black/White
3 Gray
rwo978
ND, USA
Thanks again!!
bigcat
641
Hartford County, CT
The nub on the twelve pin connector is in the first picture on the top left.
I was correct on all counts above. :) Kinda scary.
Is this the official UB412 thread yet??? :haha:
rwo978
ND, USA
Thanks. It's got the plug on both harnesses, just need to know what wire did what. Now that I have plugs that came in this week from an order, it's another project on the 'to do' list, along with other harnesses that need to be built.
n4rpd
6
Colorado
I got several of these power supplies from several SC Ultra Edge 9000 bar. I read the wiring pin out from this thread. I can't seem to get the power supplies to work. I applied power to the red fused wire and a ground to the black but I get nothing from any of the output wires from several of the power supplies that I have tested. Is there anything else that needs to be connected or triggered to turn on the power supply? Are there any other input wires that need to be connected to 12V?
Thanks,
Rob
shues
NW Indiana
If I'm reading the second post correctly, you'll have to also apply +12v DC to the grey and/or white wires to activate the pairs of strobe outputs.
