Whelen WeCan
twodogs603
1,196
Norfolk,VA
Anyone having issues programming a Justice bar with the WeCan program? I can use the program fine with a Liberty bar but just wont work for some reason with the Justice. The program says it transfers OK but its not taking everything I'm sending to it. For instance, its not taking anything Ive programmed for button 1, button 2 and 3 display the same patterns even though I set them up different, and even then, only the front half of the bar is displaying correctly what I programmed. The rear is flashing something totally different. And it wont extract the program thats already in the bar, even though it says it has. I'm at a total loss.
Andy L.
282
Michigan
If you've managed to partially program the WeCan module then that is what will be in there to extract - not the original program from the factory.
I'd recommend starting a fresh WeCan file, use just some basic programming and upload that to see if you still get similar problems. Also make sure you have the most current version of WeCan (5.0.20.0) and that you have GENII controller selected (assuming this is a new bar you're working with).
Other options available to you are to restore the factory default or flash the firmware under the WeCan drop down menu inside the program.
arnold gonzalez
