111jag
I have to a 6 volt Beacon Ray that has a 12 volt 1157 bulb in it. I cannot find a 6 volt light anywhere, even amazon. Can somebody direct me to a place, preferably in Canada, where i can buy one?
Any other bulbs that would work? And cheaper. Don't feel like paying $30 for a bulb. I'm from Canada, and we don't have anything up here.This 1183 will work well. https://www.ebay.com/itm/264899685109?hash=item3dad406af5:g:y6oAAOSwIU1fh4F-
Yes a standard incandescent 1156 is 12 volt. However, many LED replacements are 6-24v and labeled 1156. If you want to stay incandescent, an 1156 interchanged to 6 volt is an 1129. An 1156 may still work, just MUCH dimmer. Again, any BA15S base with a maximum globe size fitting your application will work, just depends how authentic you want the light to be.Remember 1156 is 12 Volt.
Will this continue to work with an 1157 bulb? I did order a 6 volt led.Yes a standard incandescent 1156 is 12 volt. However, many LED replacements are 6-24v and labeled 1156. If you want to stay incandescent, an 1156 interchanged to 6 volt is an 1129. An 1156 may still work, just MUCH dimmer. Again, any BA15S base with a maximum globe size fitting your application will work, just depends how authentic you want the light to be.
You stated it had an 1157. If in fact an 1157 bulb is correct, an LED that is labeled with 6v in it's operating range is fine. Based on dmathieu statement of the correct bulb application an 1156 would be an acceptable fit. In addition, I find it hard to believe an 1157 would be used for that light. 1157 is a dual filament bulb and more appropriate where you desire a dim light and a bright light (such as tail and brake, marker and turn, etc.). 1156 has the same dimensions but a slightly different pin location and it is a single filament bulb.Will this continue to work with an 1157 bulb? I did order a 6 volt led.
The input is 12v 2.5a and the output converter I have is 6v 15a? I let it run for 10 minutes without any heat being generated. Once again, I plan on having it on my bar and every time there is a shot I will turn it on... So that means it will turn on and off many times ..lol. Btw, are you not allowed to upload mp4 files? I had a 5 second video of it running but was unable to upload it. I'm a newbie.
Will the setup I have shown work without damaging or overheating anything?Will this continue to work?
The input is 12v 2.5a and the output converter I have is 6v 15a? The unit is a 6v light.
You are changing the design and going into uncharted territory. We can all speculate but no one can know for sure how well or how long. Will it produce light? Yes. Will it be properly illuminated? No. Will it last? Maybe.Will the setup I have shown work without damaging or overheating anything?
