Who made the best rotating halogen dash light?
mr. awesome
The title says it all, who made the best rotating dash light? I sold my Dash master and I'm now looking for a nice halogen rotator, ideally firebeam or dashlaser-like with multi flash mirror, however it is not a deal-breaker if the light is incredibly bright. My question is, what am I looking for? Is the cadet any good?
Nolines
Silver Supporter
I like the Cadets if you can find the Mirrors to go around it, super bright and fast.... though I have had the Firebeam in ocillator ( Sp ) Version for split colors... lost it to a friend when he quit the company we were working for and never returned it..
Sparky_911
Gold Supporter
Firebeam all the way. The Cadet is nice but much smaller than FB or dash laser. The hotshot II was pretty bright as well. Adding the mirrors helps with flashback too.
LineSpotter
Junior Member
The most 'effective' halogen light Ive used is one of the Code 3 Dash Lasers I own.
Its not the common one with the translucent top and bezel, but rather all black with a metal base. (to me the common Dash Laser isn't nearly as bright/effective as the one with the metal base, the reflector seems different).
It uses the same output bulb as the most of the rest, but the way the reflector is fully filled and focuses the light, in addition to the slower speed, makes it appear brighter than anything else Ive seen or used including Firebeams, Fireballs, Responders, etc.
BLUELIGHT
Established Member
In decending order, Firebeam, Dash Laser, Fire Ball Halogen, Hotshot II, Fireball2, Responder, Cadet. Those available with mirrors, especially the ones that allows the use of color and white, are a full order of magnitude better than the ones without. Probably best bang for your buck is the Dash Laser with a mirror. I didn't rate the Magnabeam due to rarity and cost. Some of these allow roof use, which is a plus, especially on scene.
Nolines
Silver Supporter
i just took out my responder, appears theres corrosion or loss of copper on the copper of the rotator, what can I use on that if the contact is causing it, maybe dialectric grease?
BLUELIGHT
Established Member
Can you get to it to polish it with steel wool? Clean with water, let dry, apply silicone grease.
CHIEFOPS
Senior Member
Dashlaser-M over Firebeam everyday and twice on Sunday. The Firebeam and mirror have an entirely impractical footprint compared to the Dashlaser-M.
If you don't need a mirror go with the Cadet, IMO the horizontal bulb and reflector project a warning signal identical to a rotating sealed beam.
cmb56
Correct, the brand is Premier Hazard. I can't find a U. S. supplier.
I checked Premier Hazard’s catalogue and the 880 is permanent mount and 880M is magnetic mount.
They are available in amber, blue, ECE blue, red and green.
ECE-R65 approved so that means high speed rotator. They did not tell what speed.
Have you contacted ECCO to see if they can order one for you on special order?
Or maybe someone in Europe are able to help you out if you want one.
Michael
cmb56
dmathieu,
Regarding the MagnaBeam, I have one of the last available from Federal when it still was able to order.
I got the version with side mounted reflector instead of the front mounted one.
Can you tell me which one is the most effective, if you know?
Front oscillating or side oscillating.
I have not been able to compare.
Michael
dmathieu
Premium Member
Front and side are equally effective, there is no difference. The reason for the side mounted is to allow for 2 different color 1/2 domes to give a 2 color signal. That is the only difference, and the only reason. It is very easy to convert side to front, or front to side by switching the arm hole in the black rotator gear.
cmb56
dmathieu,
Thank you for your answer.
Yes, I know all this but I was not sure if the lens shape did something with the effect of the beam.
I have a FireBeam with mirror, clear lens and split red/blue lenses.
It very easy to change lenses between these lights.
Michael
Nolines
Silver Supporter
I still have my red, blue and Black cover for the magnabeam, Wish I still had it it made a great traffic clearing sweep light.. wish they had made a sideways reflector to it that would definately have added to its presence.
dmathieu
Premium Member
dmathieu,
Michael
No effective difference.
Nolines
Silver Supporter
no no i always used mine in sideways mode but i mean adding a mirror for the sideways mode instead of head on single color flashing. dual color with a wider flash would have been one heck of a light...
Nolines
Silver Supporter
im actually considering making a reflector for my responder but would it be better to use metal and spray the reflectors Chrome to reflect the light ( should weigh less then the original Plastic/Lexan material they used originally ).
Nolines
Silver Supporter
you know thinking about it... isnt the newer version ( cadet ) a little taller but not as wide at the top as the responder was even all the way around...
Online statistics
Members online
11
Guests online
80
Total visitors
91
Forum statistics
Bigbear75
Top Bottom
