Wig-Wag Dimmer for PI Sedan and Utility
equipements_urgence
Banned
59
0
Chateau-Richer, Canada
We are proud to announce you the new Wig-Wag Dimmer for Ford PI series.
Designed for vehicles equipped with projector style headlights.
The Wig-Wag DimmerTM controller varies the light intensity
without using the shutters to prevent premature
solenoid failure.
Dims the lights intensity between 40 to 100% to avoid dead
spots in lighting. Ideal for vehicles with the latest headlight
technology such as the new Ford Interceptor and Explorer.
Integrated Functions
  • 2 independent headlight control outputs
  • 2 independent shutter control outputs
  • 1 Wig-Wag activation input
  • 1 Daytime Running Lights (DRL) disabling output
  • Flashing speed adjustment via easy accessible pushbutton
  • Headlights intensity adjustment via easy accessible pushbutton
  • Fast connection connectors for easy wiring
  • No external components required
Electrical Specs
Operating voltage : 10 to 18Vdc
Operating temperature : -40C to 75C
Current draw : (With a 14Vdc power source)
Standby mode : 0.3mA
Activated, no load : 250mA (max)
Headlight outputs (lamps) : Activated = + 12V ..................................... 10A (each)
Shutter control outputs (solenoids) : Activated = + 12V ..................................... 1A (each)
Wig-Wag input command : Activated = + 12V ..................................... 10mA
DRL output : Activated = + 12V ..................................... 10mA
So this does or does not control the high beam?
Does it just dim the factory headlight bulbs to simulate an alternate flashing?
Do you have a video?
There is no 'high beam' on projector headlights. Not in the traditional sense. It is a reflector that adjusts the beam for high or low. The various new HLF's dim the bulbs to produce an alternating flash pattern.
Yes sir,
I'm aware of all of that information.
But none of that answers my questions.
Hi VII !,
the Wig-Wag Dimmer controller varies the light intensity (headlight) without using the shutters to prevent premature solenoid failure.
Dims the lights intensity between 40 to 100% to avoid dead spots in lighting. Ideal for vehicles with the latest headlight technology such as the new Ford Interceptor and Explorer.
I put a small vid for you
http://youtu.be/g7uTrixc_4Q
scannerdude
