167
I want to use some rear facing red LED’s as brake/warning lights.
If I set the flash pattern to steady and use an external flasher, I’m pretty sure I can just wire the hot wire to the brake wire and the ground to the flasher (pretty sure the one I have pulses the ground and not the hot). My question is do I need to do anything to prevent it from backfeeding in either setup?
Thanks.
Thanks.
