DalmatProd
Hello all! So, I've finally been feeling well enough to get into my home office and start working on the small collection. First, I finally found a worthwhile and fairly priced 50 AMP peak power supply. (It's the QJE model PS50SW III, on Amazon for $158+). It works like a dream and have not had a single problem with it. Using it, I finally was able to test my Code 3 V-Con that MtnMan did such a great job refurbishing for me.
After testing it, I set about attaching some standardized connectors (some simple lug male/females) on most of my wire ends. I've also been able to re-test my four electronic sirens and two mini-bars. Then I came to my apparent, FS Model "E" electro-mechanical siren (pictured). As you can see, there is one long wire coming out from one hole into the inner workings. However, with a second wire visible, I'm a bit hesitant to connect a negative lead, without knowing for sure of there is a specific spot internally that has been lost or if I just need to ground the (-) lead to anywhere on the metal body. Your thoughts?
And speaking of "bodies," I've learned that Novus is a popular choice here for cleaning the lenses for the mini-bars. But what do you suggest for cleaning up the siren? Here is what it looks like in three files:
The motor housing I can take care of with some black spray paint.
So whatever you suggest, I'm willing to give it a try (other than giving you the siren!
Best regards and many thanks,
Steve
DalmatProd
Steve
DalmatProd
