I have an '04 Silverado with a Yaesu FT-2800 (Ham) radio installed. It's wired switched with the ignition, through a relay. When I transmit, especially at full power (65 Watts), the Oil Pressure guage on my dash shows the pressure dropping, ultimately to zero; and my Driver Information Center will show an oil pressure warning. Once I release the transmit button, the pressure comes back to normal.
I had a Motorola shop review the install, and they couldn't locate an apparent cause. As a result, I've kept transmitting to a minimum. The installer that initally installed the radio told me to "live with it", so I had a different shop troubleshoot it and correct the faults they found. Motorola changed it to how it is now. The Motorola installer wasn't happy with the way the original installer did it.
Any ideas?
Any ideas?
