'07 Dodge Ram 1500 ( New stuff, check it out!)
frfighter15
182
Waukesha, WI
Here is my 2007 Dodge Ram 1500 Big Horn Edition. It is all LEDs with strobe hideaways and HLF and TLF. Everything except for the strobes is ran through a switch box located on the floor of the cab.
Up top:
55" LED Outfitters Saber Rex Linear Lightbar
Front:
Whelen Headlight Strobes in marker lights
Sound-off HLF
4- Tomar Rect 37 I-LED Grille Lights Red
2- Tomar Rect 25 LED Lights (Standard Power) 1 red, 1 white
1-911EP LS12
Side:
Tomar Rect 25 Red
Rear:
2- Tomar Rect 25 Red
Whelen Taillight Strobes
Siren:
Carson 10-22 Volunteer Siren with Linemaster Foot Pedal
Federal Signal MS100 Dynamax Speaker
7,072
Tunkhannock, PA, USA
Very nice... I personally dont like the position of the lightbar, but I understand why it's mounted there... Great job!!!
VolEms
2,112
NY, USA
Very nice. I would add a Headlight flasher and let if flash slowly . I think every emergency vehicle should have one. They only cost around $40.
emt322636
507
Watertown, NY
Hey how did you get the "Ram" plate out from the spot where you mounted the controller? I have a similar sized controller I'd like to put there and can't figure it out. It's in an '09 Ram SLT but the dash looks to be about the same.
frfighter15
182
Waukesha, WI
My truck didnt come with the "ram plate" in the console. I just took a 2x4 and attached the bracket to it, and shoved the 2x4 into the slot. Its a quick and easy way to mount it with no holes from drilling or mounting.
usdemt
Vermillion SD
You need to pull off the radio bezel. The whole piece comes off and you can unscrew the pocket and go from there. To remove the bezel there are 2 8mm (I think) screw that go up from inside the cup holder compartment and the rest is just pop out tabs.
Here is a video it has the center console and 4wd shifter but skip the first parts and then he point out where the screws are and how to pull it off, its a piece of cake.
kiemartin6
