100watt Siren & Speaker Combo - Ideal for Volunteers or people on a budget. $185
SireLite
Merseyland, England, GB
Are you a volunteer or on a tight budget? Then this siren and speaker bundle is for you.
What you will receive is a 100 watt Siren Amplifier that can be mounted anywhere in your vehicle and a switch panel that can be mounted within easy reach when driving. You can also use the switch panel to power your accessories. (providing that you wire it up to a fused positive)
You will also receive a 100 watt Siren speaker with a L shaped mounting bracket.
as22.postimg.org_a2xwes92p_blaze_100watt_siren.jpgas22.postimg.org_sh8firldd_blaze_speaker.jpg
You get all this for $185 including Shipping within the US. Paypal only accepted. Any questions please pm me.
Features of the Siren:
  • 100 Watts.
  • PA Microphone included.
  • U-Shaped mounting bracket included for the amplifier.
  • Microphone dimensions: 2.5" L x 4" W x 2" H
  • Aluminium frame with Black finish switch panel
  • Functions with any existing switch or controller panels
  • Dimensions of Amplifier: 6" L x 5.5" W x 1.75" H
  • Siren tones include: Yelp, Wail, Pierce, Horn, Hi-Low, PA
  • User programmable siren allows user to connect one tone to 2 switches
  • 10 ft of coiled cable and 10 ft flat extension cable included for rear mounting.
  • Included is a 6 switch panel that has 2 Black momentary and 4 Red LED lit rocker switches.
    Features of the Speaker:
    Black finish
  • Weight: 6.5 lbs
  • Neodymium magnet
  • Impedance of 11 Ohms
  • Power rating: 100-Watts
  • Lightweight composite frame
  • 85 degree sound dispersion
  • Dimensions: 7" L x 7" W x 3" H
  • Frequency response of 700-2700Hz
  • Included standard L-Shaped bracket
GSPS629
