Good Evening,
I am trying to install a high-idle function into our 2017 Ford F-350 chassis, which didn't come from the factory with the function. The truck has the 6.7L Diesel engine.
I have located the following document outlining how to wire said function into the PCM.
https://www.fleet.ford.com/truckbbas/non-html/Q-256.pdf
I have concluded that 12V power needs to be applied to the Violet / Brown wire going to the PCM in order for the function to work, as well as the following conditions:
Parking brake applied.
Foot off of service brake
Vehicle in PARK (or NEURTRAL)
Foot off of accelerator pedal
Vehicle speed is 0 mph (stationary)
Engine at a stable base idle speed
Transmission Oil Temp above 20° F - 6.7L only
Engine Coolant Temperature (ECT) 40° F minimum.
I have wired this up, but the truck does not seem to be responding to any sort of increased electrical load. I do not currently have an indicator light wired to the BCP LP circuit.
Am I missing something? Possibly a wire that I am associating with one of the other functions i.e. SEIC, PTO use?I am trying to use the BCP mode.
