SlickTop Solutions
Just a heads up, I just installed two of these and the Blueprint amp box for the mic has a minor issue. The dip switches are backwards (i.e. the tag says DS 1 on, DS 2 off for standalone, and DS 1 Off, DS 2 On for Blueprint). For standalone operation to work the dip switches need to be: DS 1 = Off, DS 2 = On.
This was confirmed by a call to SoundOff Signal tech support this morning to make sure I didn't have two screwed up units.
So, if you install one and the mic doesn't pass audio, try the dip switches on the mic amp.
