For Sale 2010 Chevy Tahoe SSV 4WD
memorex
124
USA/ TX
2010 Chevrolet Tahoe $7500
Driven 189,600 miles
Located in San Antonio, TX.
Former Border Patrol SSV 4WD Tahoe. 2nd owner, used for lane closure/traffic control for about 3years. Only main issue was a ground problem and throttle position sensor, both fixed. Very regular oil change with full syn high mileage engine oil and has had cooling fans replaced under factory recall. Will need tires eventually and possibly torque converter (whines only when on the gas pedal). Radio works but not CD player or AUX port. I will include a factory radio if needed. A/C and heat works great. Keyless entry and spare keys with remotes.
Parts replaced over the years:
Locking gas cap
Both heater hose connectors
Oil pressure sensor
Radiator and thermostat
Driver seat cushions and cover
Dash cap added
Four rotors and brake pads
Front hub bearings
Front & rear struts/shocks
Upper control arm ball joint sway bar and rear sway bars links
Rear driver side window regulator
Please ask questions, no trades or financing. isd4@hotmail.com
htamboli
