2011 charger pursuit police power distribution center
CHIEFOPS
1,533
NYC
ok, wasn't sure where to post this.
I'm having trouble locating the police power distribution center to replace a fuse. The 2006-2010 upfitting guide states it's "located below the glove box and to the left of the right kick panel", however the 2011 upfitting guide doesn't list where it's located, leaving me to believe it's in the same location. Only problem is, it's not there. Is it tucked further up
next to the glove compartment instead of below it?
CHIEFOPS
1,533
NYC
Sean, in the 2006-2010 upfitting manual photo, the PPDC is mounted low enough that you can easily see the front lower corner of the door opening, not so on my 2011. I just double checked- removed the door sill trim, floor mat and peeled back the carpet, though this time I didn't drop the footwell sound insulation cover. The PPDC is definitely not "below the glove box", either on the right kick panel or on the firewall. I do see a bundled wire harness that goes up the forward/right corner of the firewall to somewhere next to the glove compt or on the firewall in front of the glove compt. It seems I'm going to have to remove the entire glove compt to access it if that's where it is. Is that correct?
EVModules
864
Deer Park, WA
I can testify to that with the 2008 & 2010 Chargers when there were significant changes. Glad Code4Services came around.
CHIEFOPS
1,533
NYC
code4services.com said:
Those circuits are now located in the underhood PDC. (pages 47-48 upfitter guide)
cavities: (all 20 amp)
1
2
21
22
23
24
That should read 7, 8 not 1, 2 but thanks for catching it.
GSPS629
