CHIEFOPS said:
I intend to install an LED hide-a-way in each fender tail light housing to alternately flash with one installed LED in each reverse light housing. I haven't removed them from the car yet to see how the housing is configured, my plan is to install the LED in the center area that doesn't illuminate. Is this possible?
Just to confirm, you're talking about the red lens behind each rear wheel?
I can't say for sure, but I don't think it will fit (it's a very small space that might not allow room for the
LAW head to fit without enlarging the hole a little), plus it really wouldn't give you much output
IMO (because you'd only have head on warning coming from the top of the
LAW, since there isn't a real reflector there). However, I have seen a local S.O. remove the red lens itself and surface mount ghosts/ions in place of the OEM fender tail light. I would go with an nForce (which wasn't out at the time the ghosts/ions were installed on that charger) to give you good linear warning in a small package; yeah, it's obviously a little more visible than a
HAW, but I don't think people will be looking close at the rear fender tail light close enough to see if it's OEM or some clear lens lighthead
