2012 Durango POV Install
Chewy519
11
North Carolina
Hello
Im just starting my install on my 2012 Durango. I figured I would start this post and go throught the process of the whole install.
Tips and suggestions are welcome this is going to be my first install.
For the lighting I have some items but needing alot of items
Probably going to try and find Whelen Liberty as the lightbar.
All items are going to be powered by a
SoundOff Signal ETSA380R Siren/Controller.
2- Siren Speakers mounted behind grille
Slide Switch Postion 1
REAR
1-SoundOff Tail light flasher ETFBSSN-P
2- Surface Mount Red/Amber beside LP
1-SNM E46 Red/Amber mounted in back hatch
Rear of lightbar All Red Or Red/Amber
SIDES
1- Feniex Cobra T6 Red in cargo windows
1- Feniex Cobra T3 Red passenger door windows
Slide Switch Postion 2
FRONT Red only to front
4- SNM Cobra Hideaways Red/Clear fog and turn signals housings
4- Surface Mounts Dual Color Red/Clear mounted in grille
1- Dual Head dash light Red/Clear center of dash.
Front of light bar All Red
Slide Switch Postion 3
Turns on Headlight flasher and All clear lights to the front.
Step 1 of install is power distrution center
Will update and post more pictures throught the process.
pdk9
3,834
New York & Florida
Sounds good. However, think you should stick with solid red surface mounts b/c it sounds like a lot of clear to the front if you do all dual color (plus the HLF will drown a lot of stuff out). Also, while I generally love LAWs in turn signals, I don’t think those dodge headlights are ideal for them (I don’t think their shape traps/reflects the LAWs like, for example, Crown Vic or older Tahoe turn signals)
Chewy519
11
North Carolina
Yea I was thinking there was alot of Clear to the front. I was just looking at the turn signal housing how do you think A set of strobe hideaways would work in them.
pdk9
3,834
New York & Florida
I would skip HAWs and LAWs in the front turn signals all together. I don’t think the reflector would do a great job of “trapping” the LAW/HAW output, & I wouldn’t risk the headlights with the heat from the strobes when you have plenty of other warning
Chewy519
11
North Carolina
Here is a little update.
Thanks to pdk9 for the advise.
I ordered 4 Red Feniex Fusion 40 Degree for the grille. Also changed by mind about the hideaways in the turn signals.
The power distribution center idea failed. When I seen on a form of a cubby hole under the driver seat. The siren brain and the Fuse block will be mounted inside the cubby.
The rear fuse block will be mountes in the rear cubby compartment.
I got the SNM E46 installed.
Jesseclark2448
