2013 Taurus CMHSL Mod/Fusion install
13TTPP
175
San Antonio, Tx
I found a great deal on a pair or 40 degree dual color Fusions and had been contemplating a good location. Looking at the 3rd brake light I noticed they seemed about the right size to fit inside the housing. Referenced housing is surprisingly easy to remove requiring only a light tug on the bottom edge opposite the headliner. After additional research and testing I ended up gutting the complete existing light strip and lense, and the 2 fusions fit like they were meant to be there. Mode one flashes in sync R/B resulting in a large bright block of light, with mode 2 as override on braking to the "brake pop" pattern with a double or triple flash before steady burn. I am very happy with the result as it looks like the factory set up and the operation is very slick. Rather than run power to the trunk, I tapped into a constant 12v off of the Sony amp, and switching is accomplished using a nifty Bluetooth device bought off of eBay. I am a commissioned LE officer and use the car for off duty traffic assignments in compliance with departmental policy. IMO, anyone with one of these cars should consider this easy and effective modification. Pic attached, and I'll upload a video shortly.
Reactions: StEaLtH2
13TTPP
175
San Antonio, Tx
I thought they were synchronized, the eye can hardly tell but the video makes it obvious. Next up installing a STT flasher in the amber turns. I always put a full size code 3 2100 TR on the roof for assignments, this just augments.
Reactions: StEaLtH2
pdk9
3,834
New York & Florida
Nice job. I've seen this once before with a pair of red/blue mpower fascias (doubled as a brake light) and I thought it was a great idea for super low-pro warning without adding any obstructions in the RVM. I think it'd be cool if an installer here got tri-colored lights and used them for warning, brake, and reverse
Reactions: Doug
Advancedstreet
