2014 Ford Fiesta EMS POV
zacharyr122
22
New York
This is my 2014 Ford Fiesta ST. Used for response to Station in suburban area. I'm a volunteer emt/evo for local ambulance. I did the entire install myself. Front lighting only, as follows...
Top Passenger - Sound off Signal N Force Dual Green
Center Windshield - Sound off Signal N Force Single Green
Grille Lights - Sound off signal N Force Nexus in Green x2
Controller - Just 2 toggle switches.
Have it wired so I can run the grille only at night, to avoids flashback on windshield. The top light is cutting through 30% tint, which is why it's not that bright. I personally like simple patterns, curious as to what everyone thinks!
RyanZ71
1,001
Denver, Colorado
It's Christmas!
Only suggestion is to keep the grill lights on that double flash pattern, side to side, that is where it will do the most good, not alternating between flash patterns. It gets the most attention with the side to side double flash (assuming that is a double flash if not a triple flash) And set that dash flasher to a steady flash as well, not alternating flash patterns.
acala91
1,662
FL
I would move the dual head light to the dash and flash both heads at the same time.
CACBAND
352
Bering Sea
He said he only responds to the station, so I doubt rear lighting would really do anything for him. I also only respond to the station and have only front lighting.
woobatu
