2015 F150 Marker lights to corner strobe with ULF44.
ackthe2nd
36
Tennessee
Just tap into the output wire, add a relay, flasher, and some diodes. I drew a diagram of mine, I'm sure it would most likely work with yours. You would just need to find out what wire in your harness is for your marker lights.
Reactions: Monroechj
Monroechj
3
Texas
Ack, can you share this diagram???
Nolines
1,681
Margate, FL
I do Wonder what the effect will be on the lights themselves, i remember you lose some life on the lights when they do something other then what they were designed for...
carguy411
372
ny
Can you post how you added the relay and diodes. His is what I been wanting to do to the Durango rear lights
Monroechj
3
Texas
His are not the factory leds. He replace the Amber oem leds with a switchback unit from diode dynamics then added a whelen flasher to strobe the units, adding diodes & relays to prevent feedback into the existing factory harness. I just want to see exactly where the diodes were placed so I don’t burn up my harness/get an update one how the set up is working a year later.
Reactions: StEaLtH2
ackthe2nd
36
Tennessee
Hello Everyone,
Sorry, I dont get on here much. I will be working on the truck soon and rewiring some things and will take note of how I wired it up and do a diagram and post it on here.
Correct, strobe is incorrect term. They are flasher controlled LEDs, diode dynamic switchback to be exact as someone indicated. I opened up the headlights and switched them out. Two years later... they have all failed and I will be replacing them with anzo switchback headlights.
Stay Tuned...
Monroechj
3
Texas
Looks great ack. Did any of your oem lights fail or was it just the switchback boards? Have you thought of maybe changing the switchback boards to oracles dynamic color shift boards? They have way more leds which leads me to believe they would be brighter, also with your ability to select different colors to flash.
Reactions: ackthe2nd
Nolines
1,681
Margate, FL
Not to be the Public Safety Nut here but those kinds of Lights Worry me with People who may not be very Law Abiding and try and use them in an Impersonating Manner... though they look cool I do worry that we are stepping into some areas that law enforcement and others may start coming after and make new laws governing... thats why I guess im so Old School into Halogen lights and Strobes... hard enough to impersonate with without additional work.. Still it Looks Really cool...
ackthe2nd
36
Tennessee
Monroechj,
Just the switchback boards went bad. I like that idea about the color changing. I personally don't want the 6 hour task of hacking back into the headlights. Neither did the local 3 auto shops, even if I paid them. But I do like the color changing option.
Gasman
