Circumstances dictate my next ride will be the PI Utility. In researching the options I see multiple sets of factory lights are available all around the vehicle. I checked the upfitter guide- do I understand it correctly that each set of lights has programmable flashers using Whelen flash patterns? If so, each pair can have independent patterns? And they're programmed/sync'd and triggered by wires run thru plugs inside the center stack?
