4200 mini factory headlights?
Doyle257
658
Cheektowaga, NY
probabally not. I dont believe the output is high enough.
buddek09
339
US, Ohio
Doyle is correct, the 4200 mini output current isn't high enough. However, you can wire relays to the high beams and use the 4200 mini wig wag function to control the relays.
Reactions: Doyle257
You would need 2 relays connect light to output of relay, run a power to the relay, use out put of mini 4200 1 for one lights relay and 2 for the other
buddek09
339
US, Ohio
I drew a quick wiring diagram in paint for you with how the relays get wired in.
woobatu
