911EP Galaxy Question
bkulibert
111
Mayville, WI
I have a 911EP Galaxy lightbar model #C1L/W-08. I am trying to figure out where these two wires plug into (see attached pic). I know that they are ground & power but where do they plug in as they are not connected. Any help would be appreciated. Thanks
tsquale
Oct 12, 2010
10,537
Minnesota, USA
In my experience with the dozens of them I have worked through, it is common for their to be extra plugs in them. Without photos of where the wires trace back to, I won't be able to give you a better answer.
bkulibert
111
Mayville, WI
each those wires are coming out of the thick black & red wires that are coming out of the bar. there is two small red wires coming out of thick red wire and two small black wires coming out of thick black wire.
tsquale
Oct 12, 2010
10,537
Minnesota, USA
Are they coming out of those on the interior of the bar under the metal lid or on the exterior? I don't think those are wires for the alley light. Are there any functions not currently working on the bar?
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
I agree, those aren't "heat shielded" so they shouldn't be for the halogen options. I have only messed with these a bit, @Jennifer Rose Towing and @tsquale are better sources, but I can see in your bar the other halogen option has the type of wire jacket I'd expect. These don't look like that.
I also agree this is going to be a process of elimination of what works and what doesn't (provided the bar works). If everything works then you have an unused 12vdc input it would seem. Unless I'm missing something your other bases should be covered. @tsquale ? @Jennifer Rose Towing ?
GSPS629
