911EP TDWL36 issue
StEaLtH2
2,159
New England
Howdy all, I have a TDWL36 that is NOS. Once activated, one “pod” stays steady burn at a slightly diminished power while in use. Upon shut down, this same pod stays lit until it slowly bleeds the power out of it? Anyone had this issue before? Could’ve sworn I read about this on the site before but searching did not turn up what I was looking for. I do have constant power to bar and only the trigger is switched as well as a solid ground. Any thoughts? Prior to install it was bench tested ok....
htamboli
