Amber LED heads for fog lights
CHIEFOPS
1,533
NYC
Any thoughts on using IONs or comparable light heads as low profile fog lights, is their steady burn beam pattern suitable??
bluestinger90
657
BC / California
I wouldn't use it. What happens if it accidentally changes to a flashing pattern? It would be hard to notice in the daytime. For the price of the Whelen ION's, you're better off getting something from feniex industries like Feniex Fusion 100 Light Stick - this light has a decent size metal housing to absorb the heat.
I'd try reaching out to a dealer who would be willing to special order a steady burn only light (if feniex still makes them).
167
324
Memphis, TN
Hey Chief, I can't speak to the use of ION's, but two things:
I picked up some very inexpensive PAR36 size amber LED's and run them as steady beam fog lights in amber, and I use the same lights along with some Tomar 3 pod LED's in white to supplement my reverse lights. They are tied into the reverse circuit and can also steady burn.
I would think the issue with ION's and other similarly sized LED's used as amber fog lights depend on what you're trying to achieve, I think they are better to be seen, than to use them to see - if that makes sense.
CHIEFOPS
1,533
NYC
I'm not sure fog lights have any effect in daylight fog or snowstorms, it's never occurred to me to activate them in daylight, but I've never had fog lights on any of the cars I've owned/driven over the last 35 years.
Are un-commanded flash pattern changes common with these category LED light heads?
But back to my original question, would the amber steady burn beam pattern of these current LED light heads be suitable as a fog light?
CHIEFOPS
1,533
NYC
....I would think the issue with ION's and other similarly sized LED's used as amber fog lights depend on what you're trying to achieve, I think they are better to be seen, than to use them to see - if that makes sense.
This I understand, but there are a gazilion LED heads and sticks marketed as driving/off-road lights and even amber fogs, but they're all too high profile for my taste, with my PIU I was considering permanent behind grill or quick-disconnect/mount on a license plate bracket.
Wolfie
287
Arrey, NM
Most warning lights should be in the same brightness range as head and fog lamps. I don't see an issue. More than once, I've put a blue filter over standard fog lights (halogen) and ran them through wig-wag circuitry. You seem to want the same, just in reverse.
167
324
Memphis, TN
The vertical lights on the license plate bracket are Tomar "takedown" lights. Those and the PARs on the corners all come on manually or with the reverse circuit.
CHIEFOPS
1,533
NYC
This does nothing to answer my question- are any of today's micro LED heads in amber suitable as fog lights- do they throw the correct beam/distance?
Reactions: Tony P
167
324
Memphis, TN
My bad, I just thought I would show you how I mounted mine as you mentioned mounting something similar in a similar fashion. Good luck finding out what you're looking for...
irsa76
342
Australia, NSW
If you want foglights, buy proper foglights.
Emergency lights are not designed to be used as working lights and are most certainly not compliant for automotive useage as anything other than warning lights.
If you want/need foglights and want to keep them low profile get a set of Hella Micro DE foglights, and make sure you get the specific halogen foglight version. They are very small but very, very good.
John Smith
304
CO, US
One problem you're going to run into is beam aim. Warning lights pay no attention to beam aim, they throw light fully, whereas modern headlights/fog lights cut off so as to not blind others. In order to aim them properly you'll need them pointed 30* downward, at which point they'll do little in terms of lighting the road.
GSPS629
