CrownVic97
On the 4th of this month, I coordinated with my supervisor at the coal-fired generation plant I work security/EMT at to swap out the Code 3 XL that was on the rig to a Whelen Liberty SC bar I picked up from our state surplus for cheap and customized myself. It was pheasant strike that busted a 500 halogen module, an amber LIN6, and the lens section over the busted lights, plus some feathers stuck inside the bar too . Other than that, the rest worked like a top!
The reason to replace the XL bar was that its high amp start up was causing an overload in the emergency lighting electrical system, thus making one of the Vanner flashers cut out a terminal to save itself. This killed the front center white and rear amber/red body lights. After showing this issue to the lead auto mechanic on plant site, he agreed the XL needed to be retired.
Luckily, I hoard parts from past project lightbars, so I had a good lens and 500 halogen module handy. I moved all the halogen lights to the front, set up the color scheme as traditional red/blue, and put a red and blue LIN6 in place of the halogen 500 alley lights in the end caps for extra intersection warning. I completely deleted the rear corners and traffic adviser and spray painted some cruddy leftover Liberty lenses flat black and put those in the rear. I grabbed a not-so-cosmetic-but-fully-operational MPC01 control head and made up a short harness to run in the overhead compartment of the ambulance. Wet sanded/polished what needed to be done and this build was a finished success
After getting approval from our lead safety and maintenance people, we set a day to get this done. In about two hours, my super and I accomplished our mission. BTW, he insisted on using the existing forward bolt holes for the mounting feet, so that's why it's cantered slightly up (not what I wanted to settle on, but I wasn't gonna raise the issue at the time, so....). All in all, it works out nicely for our needs as an industrial ambulance.
Old...........
New..........
BTW, these videos are the first I've uploaded to YouTube. They turned out good, but only ELB members will get to see 'em .
Old...........
New..........
