any ideas what would cause this issue?
billm
20
texas
i am having trouble with the flash pattern on a whelen turn lt will triple flash with the key on engine off if i start the truck the light goes from triple flash to single flash and i have had the whelen dealer check the lt head and they can find nothing wrong wit it any ideas on what would cause this problem?
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
What product are you referring to exactly?
Reactions: billm
billm
20
texas
Likely you turn signal output was made for non-led bulbs and is overriding the pattern.
i have the same lt on the left side and it will triple flash with the engine running or off and this is what is confusing why just the pass side also i tried to edit the post but i did not see the option
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
Try swapping them. If it follows the light head then it's the light heads problem. If it stays on the side then it's an input from the vehicle problem.
TDC
Dec 4, 2012
176
Carswell AFB, TX
Is the Pattern wire hooked up to the Power on that one side?
That may be the default pattern? That's how some techs lock in the default pattern permanently.
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
That's possible. That's why I recommend swapping the lightheads to see 1, how they are wired and 2, if the problem follows the head or remains at the same side.
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
the pattern wire is disconnected
Again, switch the two lightheads. If the problem follows the lighthead, it's the lighthead. if it stays on that side it is a vehicle issue.
billm
20
texas
thanks for all the help i tied the turn circuit wire into my trailer plug and the light triple flashes like the other side so it must be a messed up body harness from royal bodies i will trace it down but that will be for another day when it is cooler and slower
KeystoneDiesel
