Just picked up this old rotator light from an antique shop. No markings on it besides "GE 4416" on one of the bulbs. I'd assume this is a GE light but can't find any other info on it. Anyone have any info?
Thank you. I've also now been told it might be the Dietz 211. Do you know about possibly getting a new dome or base for this? I'd like to use it on my antique displayLooks to me like a Signal Stat Model 377, which is their version of the "Hill Light".
There is a lot of overlap between deitz, signal stat and grote. The bases and domes are usually the damaged part and what you have is the intact part, but maybe your could find a seized up one.Thank you. I've also now been told it might be the Dietz 211. Do you know about possibly getting a new dome or base for this? I'd like to use it on my antique display
Thank you John. I appreciate the help.There is a lot of overlap between deitz, signal stat and grote. The bases and domes are usually the damaged part and what you have is the intact part, but maybe your could find a seized up one.
I can say with confidance that that bulb cage is Signal Stat, and not Dietz.Thank you. I've also now been told it might be the Dietz 211. Do you know about possibly getting a new dome or base for this? I'd like to use it on my antique display
Does it happen to be model 377?I can say with confidance that that bulb cage is Signal Stat, and not Dietz.
I concurI can say with confidance that that bulb cage is Signal Stat, and not Dietz.
I will defer to you guys, my dietz, signal stat grote knowledge isn't vast by any means.I can say with confidance that that bulb cage is Signal Stat, and not Dietz.
