Anyone know of low profile antenna's?
poesdad
86
Bend Oregon
We have four antennas on an unmarked that look horrible. Here is the equipment list that needs them.
Mdt (currently using 800mhz radio modem)
800 MHz main police radio Motorola
100 or 150 MHz fire radio. Motorola also
Cell phone
Are there antennas out there that r flat?
acs680
220
Tennessee
Cell phone
Your best bet for antennas is Tessco. As far as completely flat, not really, but you can get some that are around an inch high. The VHF might be a little tricky though...
Mobile Antennas | TESSCO 800 472 7373
wkr518
955
42.791127, -73.679758
can't remember where we got them or customer got them, but we did a DEA or ATF car that had an antenna behind the front bumper.Radios were Spectras.
MPD 818
1,317
Murfreesboro TN
I have always had good experiences with these type antennas:
they come in a variety of shapes and sizes for the different freq bands you are needing. I am not sure if this would interest you but there are also Stico antennas which are made to look like factory antennas, they cover a wide range of freq's and have various configuration options.
STI-Co | Antenna Manufacturer | Antenna Systems | Antenna Accessories
Zapp Brannigan
May 23, 2010
3,580
I have the bottom one which works great!!
lafd55
2,393
New York, USA
AKRLTW
257
AK/NV USA
Maxrads low profiles ain't too bad. But, totally flat antennas are honestly not going to have the best radiation pattern, so your transmission and reception may suffer.
This is a maxrad cellular antenna on the trunk 800/900 mhz and 1800/1900 if I remember correctly. The roof antenna is a VHF/UHF dualband antenna for amateur radio.
EVModules
864
Deer Park, WA
What POWER are you operating with that antenna? It looks either glowing or has cooked the paint around it! :faint:
Jun 26, 2010
324
Massachusetts
Everything is usually ok except for a vhf system. Everyone I know hates the vhf antennas because they work decent near the repeaters but anywhere outside of the city the reception is very poor.
Ben E.
Iowa, USA
The low-profile "can" style phantom antennas have an EXTREMELY low bandwidth, like within 1mhz or less if I remember correctly. So unless you can tune the antenna to use 1 channel, or several channels within that 1mhz, you're pretty much screwed there. I'd just stick with a 1/4 wave VHF antenna. I had one on my Explorer when I worked security, and I would drive through 5 parking garages a night, 4 times a piece. So I drove through 20 parking garages a night, and the VHF 1/4 wave would slam on every single cement rafter as I drove through several stories of each garage and it still outlasted my employment there (several years).
bwoodruff
499
Upstate NY
+1 for 1/4 wave antennas from Tessco. Four of these cut to the correct length will cover all of your needs:
Laird Technologies QWFT120 118-512 Field tune 1/4 wv | TESSCO
$40 in antennas (gold pricing) you can hardly go wrong.
(they have an 800MHz version as well, same antenna but smaller size for 800MHz)
poesdad
86
Bend Oregon
So, will this work for VHF or not?
If so, how tall are they?
The link below is what it looks like we will use for 800 and cell.
Concealed Internal Antenna SystemSti-Co | Sti-Co
VHF ham band antennas are around 19inches long. since public safety freqs are higher than ham bands the antennas are slighly shorter. around 17 - 18 inches.
poesdad
86
Bend Oregon
I guess I'm still a little confused. Are there any other "covert" options for VHF antennas?
Will the small fin kind work? Or are those only for 800?
:confused:
Zapp Brannigan
May 23, 2010
3,580
lafd55 said:
It's frost.....
Exactly right!!
:confused:
If you see the picture I posted in the thread, the Laird phantom "fin" antenna I have is on UHF, and I get great service from it!
poesdad
86
Bend Oregon
Exactly right!!
From what I can find on google, UHF works on a higher frequency than VHF. So, UHF won't work on the 150 fire radio. Right?
Zapp Brannigan
May 23, 2010
3,580
bwoodruff
499
Upstate NY
Antenna length is based on the frequencies that the antenna will be used on. "UHF" is in the ~450MHz range, which is very far from "VHF" which is in the ~150MHz range.
Without getting into a lot more radio theory than that, the basic idea here is you are going to need three different length antennas:
The longest for VHF
Medium sized for UHF
Tiny for 800
An 800MHz antenna is incredibly small (at 1/4 wave) anyway, so there is no need to look for "phantom" or "low profile" 800MHz antennas. The same is pretty much true of UHF as well. They really aren't that big (at 1/4 wave). VHF I can see wanting a lower profile than the standard 1/4 wave whip... so that is the one I'd consider going low profile on, especially since it sounds like that band is least essential to your operation.
safetyco1
108
Florida
Cell phone
Yes there are several. Th only problem will be the VHF. the only colr for VHF is white 3" dia 31/4" tall
800 and cell phone are 1" diamiter and 2.7" tall
Price are app 50 each ( uses standrard NMO mount ) Mount and connector not included add 20 each with connector.
I use these all the time they work great. I install around 20-30 of these a year.
Ben E.
Iowa, USA
Holy cow, 20 bucks for a connector?
citypolice
37
NCR (VA, MD, DC) USA
Cell phone
I know I am a bit late to reply and don't usually bump old threads but I am very curious as to what antennas you ended up using and how is it working for you?
I am in the process of building a Chevrolet Tahoe with 21 devices and only 5 visible two way radio antennas and one barely visible GPS antenna added on the roof.
For your scenario, there are many different combinations to use (including the behind the bumper antenna) based on your budget, but I would use the following to provide best possible coverage on all the devices you need to use:
Dual band for the police & fire radio > Dual Band Antenna | VHF Antenna | UHF Antenna | 700 mhz | 800 mhz | Sti-Co
MDT > name brand (antenna specialist or PCTEL) commercial cellular on glass antenna (no need for a special covert model if your MDT uses traditional 800 MHz freqencies.)
Cell Phone > who uses in car mounted cell phones any more. If you do > try the Concealed Internal Antenna SystemSti-Co | Sti-Co
Muxlow
217
Middlesex/ontario
These are some of the setups iv used on my car
1st shot
Roof is a Maxrad 800mhz antenna, was about 2 inches
behind that close to the glass was the Laird low profile fin type antenna 440-460mhz i think that one was.
Both of them worked AMAZING
Trunk is a little maxrad 8/900mhz antenna
and then a 16 inch VHF whip
Iv since changed this
Trunk is a UHF white about 5 inches ish
Trunk is the 800mhz antenex stealth antenna
Roof iv got a 800mhz AntennaPlus Millenium that also does GPS
Last shot was my first setup
Had the stock car antenna on the roof with the maxrad 800mhz antenna, then a mag mount on the trunk plus the VHF antenna
The only "low profile" VHF antenna iv ever seen other then a glass mount cellular look a like or one to replace the stock antenna on cars has been the Laird Tech TRABT2100 - $77.95 : The Antenna Farm, Your two way radio source
A friend had one to replace his whip antenna.. and good god was it not only UGLY but sure did stick out WAY more then the other one he had. I dont think they are low profile at all.. MAYBE if its ontop of a SUV or something but for sure not on a car. It was about as tall as a pop can
Alot of good antenna companies make nice stealth antennas the look like stock ones. Could always look into one of them for VHF or a nice glass mount one that would look like a cell antenna.
So could use an antenna like the AntennaPlus style for the roof for use with the MDT, A antenex low profile style also on the roof for 800mhz, and the glass mount/stock style antenna for VHF. Unless you went with a 1/4 wave whip like for the trunk or back side of the car to look "stock" like
jeaustin924
