Assigning Value
QUICKONE
43
ARIZONA
What would you assign an approximate collector's value for the following items;
Code 3 (PAR36) Mini Bar with front facing Stinger, (Clear Dome) in Good Mech Shape
NIB A Pair of Whelen VL-12 strobe heads (CS240 P/S) with 1(ea) Split Red/Blue and Red/Amber Lens.
Jun 18, 2013
3,725
PA
Value largely depends on condition. Pics would help. If the bar is in good shape and a sealed beam version, I would say $150-$300 with $300 needing to be MINT.. IMO
QUICKONE
43
ARIZONA
They're packed away at a storage unit. I'll dig them out when I'm up there again.
The SD Mini is sealed beam and at a 7/8 cosmetic condition, dome needs to be polished but at a 9 Mechanically.
The VL-12s are NIB and both are Split Domes
Jun 18, 2013
3,725
PA
the SD is probably closer to the $200 ballpark.
You'll need a Whelen guru to give a value on the light heads..
Reactions: stansdds
htamboli
