CenCom Red; SS2000SM; Whelen LEDs; Fed Sig Jet Solaris, Vista SL LED, 460L PS; Custom cut strobe cab
rwo978
ND, USA
Fine Print:
  • Outright sale for the most part. However, I have a small list of wanted items I may trade for. See link below.
[*]Payment by money order preferred. However, will take PP on lower dollar amounts.
[*]All items are tested to ensure functioning before shipment (where able).
[*]No warranty by me on items. If items still covered by warranty, manufacturer warranty process will need to be followed.
** FedSig mini Jet solaris - Can be All Red., All Blue, or Red/Blue combo. Perm mount. Clear dome, cleaned up as best I could (wetsand & polished, a lot better than it was.... **Well, awaiting a new dome.... this one fell off shelf and cracked... :mad:  **). $295 shipped.
ai667.photobucket.com_albums_vv36_rwo978_Sales_20warning_th_P2160014_zps4e1489e8.jpgai667.photobucket.com_albums_vv36_rwo978_Sales_20warning_th_PB150059_zps4e767dac.jpg
** Whelen Liberty corners - Remanufactured. LIN12 shorts. Set of 4. Out of warranty & defective heads w/ original LEDs removed, board cleaned up, and new high quality aftermarket 3W LEDs installed, wilson style. Will warranty my work 2 years from date on the Whelen style sticker, listing date, color, and handle/tag/username. Clear and Amber on hand, Green coming shortly.
          - Clear, 2 sets of 4; $325 shipped / set
          - Amber, 1 set of 4; $325 shipped / set
          - Green., coming soon; $350 shipped / set
ai667.photobucket.com_albums_vv36_rwo978_Sales_20warning_th_LED_20Swap_207_zpsij0irtcw.jpgai667.photobucket.com_albums_vv36_rwo978_Sales_20warning_th_LED_20Swap_2016_zpsbu7z0hl4.jpgai667.photobucket.com_albums_vv36_rwo978_Sales_20warning_th_LED_20Swap_2017_zpspnfjyy1k.jpgai667.photobucket.com_albums_vv36_rwo978_Sales_20warning_th_LED_20Swap_2019_zps6qhckcqu.jpg
** Whelen CenCom Red - Includes head, amp, and 'cloned'/reproduction cables, programming cable and CD. Arrowstick board has been removed for use in CCGolds, so will contol 2 wire arrowsticks only. 2 setups, 1 sold.  $215 shipped ea OBRO.
ai667.photobucket.com_albums_vv36_rwo978_Sales_20warning_th_WhelenCenComRedpair_zpsc102ebba.jpgai667.photobucket.com_albums_vv36_rwo978_Sales_20warning_th_P1030009_zps28913d9b.jpg
** FedSig SS2000SM Smart Siren - Includes head, amp and wiring; control head cable not pictured, in a box in the garage. $225 shipped.
ai667.photobucket.com_albums_vv36_rwo978_Sales_20warning_th_FedSigSS2000SM1_zpsdf699d0a.jpgai667.photobucket.com_albums_vv36_rwo978_Sales_20warning_th_FedSigSS2000SM2_zps7d38bca4.jpg
** FedSig 460L power supplys - Nice used condition. Completely tested, everything works. 4 strobe outlets, 2 negative switched led outlets/flasher. All leads/plugs included (commonly missing). Can add strobe cable @ .$35/ft to nearly any length, and add connectors as priced below as well. Add strobes and LEDs and you're set!!. 3 qty supplies. $35 shipped ea (plus extras if applicable).
ai667.photobucket.com_albums_vv36_rwo978_Sales_20warning_th_Fe6ad9af64b439a1505576c68b14fdbda7.jpgai667.photobucket.com_albums_vv36_rwo978_Sales_20warning_th_Fefc3369f19ad436348ed226f0dde070cc.jpg
** Federal Signal Serial Interface Box - New custom made reproduction harnesses, EXACT wire coding/coloring used at the factory (I got lucky when I found it reel remnant). I can also build just the reproduction harnesses. $55 shipped per SIB & harness; $25 shipped for a harness.
** Whelen Halogen 500s - With Liberty bucket. Tested and working. Amp plugs. Appx 10 available. $8 ea + S&H.
http://i667.photobucket.com/albums/vv36/rwo978/Sales%20warning/PB150060_zps62b06222.jpg
** ShoMe/Nova/Able2 Microthin Blue strobe lens, New Old Stock. Price is for the pair. Bought for replacement on lightheads, then sold them. Unused. $15 shipped.
http://i667.photobucket.com/albums/vv36/rwo978/Sales%20warning/ShoMeNovaAble2MicroThinlens_zps6c02b451.jpg
** Federal Signal Jet dome - Amber. Good used condition, should polish up nice. Not a lot of weathering or crazing, just some surface wear. $32 shipped.
** Whelen RB6 Rotobeam dome - Purple/Magenta. NOS, RARE!!!. As seen in link, it's the twin I'm keeping. $40 shipped.
** Small 12 volt power supply #1 - Includes 1 computer style AC cord and 12 volt power supply. Output is 12 volts @ 3.3 amps. Buyer can cut off the plug end and install desired end connectors. Perfect for desktop / benchtop testing of small 12 volt electronics, such as LEDs. Example vid shows voltage and powering a Whelen TIR3. $13 shipped ea.
http://i667.photobucket.com/albums/vv36/rwo978/Sales%20warning/PowerSupplylable_zps541d49c8.jpg
http://i667.photobucket.com/albums/vv36/rwo978/Sales%20warning/PowerSupply_zps90414aed.jpg
http://youtu.be/OZXXEC0oynY
** Small 12 volt power supply #2 - New, unused. Includes wall plug with different plug adapters for different countries. Output is 12 volts @ 1.0 amps. Buyer can cut off the plug end and install desired end connectors. Perfect for desktop / benchtop testing of small 12 volt electronics, such as LEDs. $11 shipped ea.
http://i667.photobucket.com/albums/vv36/rwo978/Sales%20nonwarning/th_PowerSupplyPlug_zps6e49dbe1.jpghttp://i667.photobucket.com/albums/vv36/rwo978/Sales%20nonwarning/th_PowerSupplypluglable_zpsc09d08d6.jpg
** Amp plugs & pins. Qty of plugs available. Kits include 2 new plugs & 4, 6, or 8 new pins/sockets. Includes a complete plug (2 ends and respective number of pins/sockets). S&H additional. Can sub all one end or the other for custom needs.
-2 outlet kit (Liberty modules) - $1.25 ea
-3 outlet kit (strobes/HAWs) - $1.75 ea
-4 outlet kit - $2.25 ea
https://s3.amazonaws.com/listingimages.dealbird.com/8ekVpk1eCGg7.jpg
@@@ Custom Cut strobe cables!!!! To any length!!! @@@
$.35/foot. Add ends above, additional charge, if needed.
EX = 2 10 ft cables: 20 ft @ $.35 = $7.00, with ends, 2 @ $1.75 ea, $3.50.... overall $10.50. S&H not included.
Sold:
** Whelen 43/400 5mm lighthead. Blue.
** Whelen LAW 2 head kit. Amber/Amber. Used. 2 qty kits.
** Whelen 52 lens lot. Red & Blue.
** Whelen Avenger. Dual Red/Red. Direct wire. 7/08 DOM. Includes shield.
** Whelen LINZ6 Amber. 2 qty.
** Whelen CON3 - Clear. 6 qty.
** Whelen Ion - Amber. NIP. Opened package.
** Code 3 Narrowstik LED controller. New old stock, 2011 manufacture date. 3 qty.
** Federal Signal Serial Interface Box. New in package. Part #8583446D. Late 2012, early 2013 manuf dates. 4 qty.
** Whelen Talons - Single. Passive. Blue. Short cut cord, 2 pin amp plug installed. Mount and shield. #2, #3
** Whelen TA controller - TACTL1D. Used, but functions fine. Include power harness only.
** Whelen Innerbeams - Pair, Blue/Blue. LIN6. CVPI model.
** Whelen CON3 Amber lighthead. 12 qty.
** Whelen Responder LED flasher - 4 qty.
** Whelen Talons - Single. Passive. Blue. Cut cord, (with mount and shield). 3 qty sold.
** Federal Signal LED flasher - Intelliflasher. Model 8554037 Series C & Series B.
** Federal Signal FA3 flasher. Used
** Whelen LINZ6 - Amber. NOS. 3/13 DOM. 4 qty.
** Federal Signal Cuda led stick - OHP unit, Red & Blue. Includes a FedSig LED flasher.
** SoundOff LED3s - 2 used Red. New style w/ updated pattern list. No gaskets.
** FedSig Smart Siren SS2000SM-SD - Tested and working
** Whelen Liberty Corners - Red. LIN12. 2005 dated. 6 qty.
** Whelen TIR6 - Pair, Blue/Blue. 3 wire (pos, neg, sync).
** Whelen Dominator D8 - 'Dumb' unit negatively wired for TA/Arrowstick. 8 Blue TIR3s.
** Whelen D8 Housing - Complete (9 spacers, 2 endcaps), minus LEDs, flasher and wiring.
** SoundOff LED3s - 2 used Red. Dumb/steady burn, require flasher. No gaskets.
** Whelen CON3 - Amber. 6 tab mount. 3 sold.
** Whelen Responder LED housing - NEW. Clear dome. 2 qty.
** Sound Off UltraLite 8 Arrowstick - 8 lamp, all Amber. Long cable.
** Whelen Dominator D4 housings - 2 qty. Complete, just add LEDs.
** Unitrol Touchmaster UTM4 - Nice used condition.
** Federal Signal Smart Siren SS2000SM - Version SD.
** Whelen Freedom custom mini - Factory 9000 mini frame with updated internals.
** Whelen TIR6 - Blue (lighter hue). 2 wire, requires flasher.
** Whelen Liberty Corners - Blue. LIN12. 4 qty.
** Whelen Cencom Gold - With TA board. Complete unit.
** Whelen TIR6s - 6 total. Pairs, Clear/Clear (sold), pair Red/Red (sold), pair Blue/Blue (sold). 4 wire (pos, neg, sync, pattern).
** Whelen Freedom corners - Pair, Blue. Ballast
** Whelen Custom Mini Liberty
** Whelen InnerEdge - Passenger side unit for Impala, 5 heads, no TakeDown. All Amber
** Whelen LINZ6 - Pair. Amber
** Whelen Dominator Housings - Pair D3
** Whelen TIR6 - Pair. WHITE. 2 wire
** Whelen Responder LED housing - For old style LIN6s with 6 tabs. Clear dome, base, and 6 module buckets.
** Whelen CenCom Gold - Complete. With TA board for 'dumb' arrowsticks. Custom built harnesses. Programming cable.
** Whelen Dominator Housings - Pair D1. 2 qty
** Code 3 Deckblaster - Strobe version, 4 flash patterns. Choice of blue or red. Several qty
** Whelen Justice corner module pair - 2 12led Red heads with bracket.
rwo978
ND, USA
Reserved
rwo978
ND, USA
Updated, sold items removed, qty updated. Added dual RR Avenger.
rwo978
ND, USA
updated
rwo978
ND, USA
Updated
rwo978
ND, USA
Updated, added Liberty RED LIN12 corners.
rwo978
ND, USA
updated, sold item. added pics.
rwo978
ND, USA
updated.
rwo978
ND, USA
Added Whelen TACTL1D.
rwo978
ND, USA
Updated
rwo978
ND, USA
updated
rwo978
ND, USA
:bump: :bump:
rwo978
ND, USA
updated
rwo978
ND, USA
updated
rwo978
ND, USA
updated
May 23, 2013
458
nc
do u have anymore of the fed sig led flashers left?
im interested in one
rwo978
ND, USA
yes, still have several
rwo978
ND, USA
updated, added a couple items and items sold.
rwo978
ND, USA
Updated, new items added and pics fixed.
rwo978
ND, USA
Lseg810 said:
just to clarify..the dominator has Amber LEDs or Blue?
Blue. The amber were replacement for the blue.
rwo978
ND, USA
updated
NCAP126
202
New York
Do you still have the blue talons? Looking to swap out ambers in two dual talons R/A so I will have ambers to trade back. Have freedom blue corners and 6 over 3 blue amber 400s to trade no diffusers in both.
rwo978
ND, USA
Yes, still have the blue. I could actually use the amber too. Send a PM on swapping led boards.
rwo978
ND, USA
updated. TACTRLD1 & InnerBeams SPF.
rwo978
ND, USA
updated, sold items removed. InnerBeams and TACTRLD1 available again.
rwo978
ND, USA
updated
rwo978
ND, USA
Updated.
rwo978
ND, USA
updated.
Returning soon, custom cut strobe cables... to any (reasonable) length!!!
rwo978
ND, USA
updated
(working off my tablet unless I have sporadic access to a desktop, laptop took a dump... In otherwords, bear with me.)
rwo978
ND, USA
:bump: :bump:
rwo978
ND, USA
Updated again, added pics and SS2000SM
rwo978
ND, USA
updated
benny22
