Cencom sapphire programming question
FFRNDAN
98
Malvern, OH
I've got a Cencom sapphire I am attempting to program to my own preferences using the most recent version of Whelen Command.
Is there a way to disable siren tones, other than the air horn unless the slide switch is in position 3?
NoLimitSquads
351
Minnesota
Set your external siren to off in every state that you want it disabled in. Go into priorities, and set the airhorn and position 3 above the states that you want it disabled in. That is one way. Another way would be to make in event. If slide switch 3 is not on “or” airhorn is not on. Make sure to link the two conditions. Then turn external siren off. If you want your PA to still work, set your PA and PTT to top priority. And/or add it as an additional condition to your event.
aidey1234
