Code 3 360 Intersection Light options
Chris18
68
Victoria, Australia
Hi all,
I wanted to ask if anyone would happen to have any pictures of the Intersection Light options that were available for the Code 3 360 light bar? More specifically, I'm trying to work out how the lights are mounted where the motor is against the outer edge and the reflector sits down in the front section. I've attached a screen-shot were the motor position is highlighted (sorry for the quality - it's zoomed in on a larger picture!).
I've tried various positions with the thinner style intersection lights I have here (I'm attempting to build a 360 light bar that had this set-up) but they don't seem to fit as pictured. Were these mounted on separate brackets?
If anyone has more info or pictures it would be much appreciated!
Kind Regards,
Chris.
Berlin, MI, 48002
They had a few options...one was a large sweep like an MX7000 on a bracket. They also had dual "X-Fire" Strobes, dual sweeps (Excalibur style) & dual LEDs stacked I think (Those I have never seen).
I had to do some rigging a long time ago & used a couple long plastic spacers & long screws to "lift" the single larger MX style sweeps up to where it needed to go.
woobatu
