Code 3 Force 4 XL Power Supply
Jacob K
64
Canada
Hello all and thank you for viewing this thread!
I currently have a Code 3 Force 4 XL all amber. I’ve found it hard to get a power supply but i was given a Samlex Power SEC-1223 power supply a while back. I just got it out and wired it up but it won’t power the bar, almost like it’s not getting any power, but when i plug in my smaller light it workds just fine. Can anyone share or help me with my problem?
Thanks!
Elmira, ny
Probaly not enough Amps to power the bar.
They usually pull about 30 Amps (or around there). I have 2 of them and I usually just test them once in awhile
Jun 18, 2013
3,725
PA
Amperage draw will be dependent on the bulbs in the bar. Take your bulb wattage and divide by 12 and this should give you an approximate amp draw.
So for example H1 bulbs are 55 watt. so 55/12 = 4.58 amps. Typically XL5000s came with either 795 (50watt) or 796 (35watt) bulbs..
figure out the type and multiply by 4.. then factor in 1 or 2 amps for motor draw.
Keep in mind also that Halogen bulbs draw a fairly large surge on cold start which can be quite high.. So in your case a 23 amp powersupply may power the bar post startup surge.. but you'll need 30 or higher to get it rolling.
Jacob K
64
Canada
will LED bulbs make a big change?
Jun 18, 2013
3,725
PA
Yes in 2 ways..
Lower amp draw..
probably a fraction of what its drawing now.
But also LED bulbs cast light differently the halogen bulbs and it may not be acceptable for your end result.
see this video..
Reactions: thatoneiowan
MtnMan
1,533
Eastern PA
Assuming this is for display purposes only, you can replace some or all of the halogen lamps with #93 lamps, which are only 13W.
Reactions: jdh
benny22
