code3 arrowstick 10 lamp controler
denko3
866
SLOVENIA,EUROPE
hey guys!
can someone please tell me or have some wiring manual if i can wire MX internal 10 lamp arrowstick on basic controler which is for 8 lamp control?
or is the controler for 10 lamp other special?
Shawn L
Corbett, Oregon
some of the 10 lamps just paired the outside 2 lamps, typically the end (outside) lamps would be a single wire with 1 bulb each, but I have seen the 10 lamps that have the arrow and second in lamp wired to the same curcit
denko3
866
SLOVENIA,EUROPE
i am just scared that i won't burn out the controler because of too much input load.
what would you do....what do you think?
Shawn L
Corbett, Oregon
each other out put can handle 2 lamps on at the same time , I highly doubt that the end circuit components are different . I have wired a 10 lamp internal to a standard 8 outlet as described. ran it for years with no issues
denko3
866
SLOVENIA,EUROPE
aha ok Shawn so you say it won't be any problem if i wire 10 lamp internal Mx arrowstick on basic or delux code3 controler?
StormChase85
